Clutch
SD
Clutch
Hey had a great weekend of bashing had a few issues i thought i would throw out there tho... First off i was running in about 50 degree weather (thanx to my folks living in Mo.!) and was running a mc9 plug was tuning dut to my buying a infared thermo from sears.....kinda nice one but well worth it! anyways i was having a problem with it ideling up then ideling down at stand still then when i took the ignitor off and hit the throottle it would die!!!!???? No idea but if i left the ignitor on and ran a bit then kinda let out of it enought to grab the ignitor off as it went by no problem till i few low speed passes and then it would die out again? I also was tring to take the spurs off to get at the clutch and boy thoe buggars are stuck onany tips??? I was wandering did anyone else have problems getting them off? Is it easier to take the whole motor off to do? Just wandering! thanx for any help!!!!!
CA
RE: Clutch
You might have a bad glow plug, that is not getting hot enough or is just passed due. happens.
if your trying to mess with the pinion gears i would take out the engine from the motor mounts up on top (4 screws) and untie the header pipe spring and voila the hold shebang comes out.
SD
RE: Clutch
Thanx answered my ? ....i think my glow plug was still a lil cool is tha problem tho! running a mc9 in about 45-50 degrees still a lil cool i think!
