2nd batt back (hump)
FL
Would some post a pic where the 2nd battery pack gets mounted? I got the batteries and "y" harness made up. I don't have the truck yet, Hope to see it thursday. Just wanted to solve the mystry in my noggin. Thanks
FL
RE: 2nd batt back (hump)
I was trying to build the packs BEFORE I got the truck. It should be here friday. I travel alot and wanted something to work on in the motel room. Boy if you thought I had the truck allready you must have thought "this guy is a real dumb sh*$! Thanks for the help JFEX
CA
In jefx's defense I knew what you were up to and almost took mine apart to measure the wires for you but to be honest you're installation might look nothing like mine.For instance my wires run underneath the rotostart backplate where there's a remote possibility that the rotostart shaft could abrade them.Something I'm careful about and willing to live with but maybe you might not and you may think a different route is better........and would curse me later for giving you dimensions of a wiring harness that put the wires in harms way
Peace
Peace
ORIGINAL: hoverlover9797
I was just thinking that there are several ways you could run the wire, so just use whatever works for you. I didn't realize you wanted the packs done before you got the truck.
get your truck, then do your engineering.......its hard for someone to explain every in and out about something without you having a reference......we are here to help, not do it for you. Edit is a smily face...didnt want to come off as a #$$@$head
Let's see...bored inhotel room looking for something to do to keep busy..have internet access.....
