LST Standard Hub Size?
Hi Guys
I'm new to these things with wheels usually play with rotors. Can you guys tell me the standard hub size of the LST as I want to get new set of wheels and tires and need to know what to ask for.
RE: LST Standard Hub Size?
The 14mm hex (for LST) is the same size used for the Savage, Tmaxx, MGT, and TNX. Any wheels for any of these trucks should also fit the LST.
ORIGINAL: Ozzy Pilot
Hi Guys
Hi Guys
http://hobbypeople.net/gallery/145530.asp
I have a set (as do a lot of others here at RCU) and they are huge! 2 people that have posted here have broken a wheel, but keep in mind that a lot of people here drive these trucks HARD! I have them on for driving araound the neighbourhood and street ripping (the neighbours love it!) but put teh stockers back on if I am going for big air...I think theye are stronger, and I KNOW they are lighter ( by almost a pound in total frot he 4)
PM me if you have any questions about these wheels or anything else Losi/AUS combined..I have had a bit of ecperience with shiiping things and sourcing them here in Oz
I don't know if the stock wheels are stronger or not than the XTMs. I think it has more to do with the sidewall profile. The stock wheels are smaller in dia., and the tires have more sidewall, which results in more "cushion" when landing big air.
The Meats are lower profile and don't provide as much "cushion" when landing, which means the wheels take more stress.
ORIGINAL: jefx
NY
JEFX: What do you think of the Pentos/meats combination for race condions as opposed to Bow Tie 40's on the LST. What would you expect the performace difference would be between the two setups? Do you think the Pentos/meats would work at all under race conditions on hard pack dirt surfaces?
NYCREW
NYCREW
