Radios
ON, CANADA
Radios
What's the difference between the 27 and 75 mhz radios that come with the LST? [sm=confused.gif]
Is the 27 mhz synthesized?
Does one reach farther than the other?
Does one have more features?
What's the difference?
ON, CANADA
RE: Radios
So the 27 mhz runs on crystals and you can only buy up to 6 different channeled crystals for it, and it only comes with one crystal, while the 75 mhz one comes with a synthesizer that reaches 30 channels without buying any extras.
Does the 27 have multi model memory and all the other things like exponential servo rates and all that jazz?
ON, CANADA
RE: Radios
The reason I'm wondring is that on ebay there's one selling for $450 with the 27 mhz and I was wondering if it's worth it. Does anyone know if you can get a syntesizer module to fit in the 27? If so which one?
CA
RE: Radios
The JRX3 is not a module type radio.As far as I know you have to go up to the JR-1 for that feature and even then it's questionable if the available synth modules work with it as well
RE: Radios
Thats for saving different trims and epa settings etc, for different models that use the same crystal, its so you can multiple models running on the same crystal as different models will need different settings.
IN
RE: Radios
[link=http://searcht.netscape.com/ns/boomframe.jsp?query=XS3+radio+27&page=1&offset=1&result_url=redir%3Fsrc%3Dwebsearch%26requestId%3D3 eb239a6e227b4e8%26clickedItemRank%3D6%26userQuery% 3DXS3%2Bradio%2B27%26clickedItemURN%3Dhttp%253A%25 2F%252Fwww.horizonhobby.com%252FShop%252FByCategor y%252FProduct%252FDefault.aspx%253FProdID%253DJRP3 17227%26invocationType%3D-%26fromPage%3DNSCPResults%26amp%3BampTest%3D1&remove_url=http%3A%2F%2Fwww.horizonhobby.com%2FSho p%2FByCategory%2FProduct%2FDefault.aspx%253FProdID %253DJRP317227]27 crystaless[/link]
Using synthesized signal processing, the XS3 allows racers to dispense with crystals and adjust their systemÂ’s signal to whatever frequency the track environment requires. No more sitting out a heat because someone else shares the same channel. Racers can simply tune in an unused frequency and continue racing.
[link=http://searcht.netscape.com/ns/boomframe.jsp?query=JR+XS3++27&page=2&offset=0&result_url=redir%3Fsrc%3Dwebsearch%26requestId%3Df 4c21509302e7442%26clickedItemRank%3D13%26userQuery %3DJR%2BXS3%2B%2B27%26clickedItemURN%3Dhttp%253A%2 52F%252Fwww.modelflight.com.au%252Frc_model_radio_ control%252Fjr_propo_xs-3_rc_control.htm%26invocationType%3Dnext%26fromPag e%3DNSCPNextPrev%26amp%3BampTest%3D1&remove_url=http%3A%2F%2Fwww.modelflight.com.au%2Fr c_model_radio_control%2Fjr_propo_xs-3_rc_control.htm]Here another 27[/link]
I thought and still believe that the only dif is the 75 has 30 channels and the 27 has 6 TO CHOOSE FROM AT ANY GIVEN TIME.
RE: Radios
The 27mhz that came with my uk truck used xtals. i am not sure what the american sets come with but everyone seems to be paying the extra and going for the 75mhz trucks
SD
RE: Radios
I also have the 27 and i have to agree i think the only difference on the us production model is that there are less channels to choose from!! No crystals at all! it is synthesized! If u need to change channel u just turn the dial on the receiver then u change the number to maytch on the radio! I am not sure if the 75 has a 20 model memory but the 27 is only 6! other than that they are the same radio!
ON, CANADA
RE: Radios
Well, everyone thanks for all the responses.
Will the 75 reach 27 channels? I have 2 other cars that are both 27 and was wondering if I could use the 75 with those two
CA
RE: Radios
ORIGINAL: Sgt. Canada
what do they cost? why? are they better?
hope this helps
CA
RE: Radios
I know the 75 mhz version comes with a synth receiver but can't speak to the 27 mhz.I'd imagine that if the TX is then the RX would be as well.One of the UK guys can probably be more helpful
