Various and sundry weights
CA
So in the proces of modifying truck #2 I've kept a log of the weights of various pieces and their stock counterparts and thought you guys might be interested in what's been compiled so far.
mach .26 engine w/pipe,roto start back plate,motor mounts and air filter 642 grams
pair of upper a-arms plastic with hinge pins 56 grams
pair of adjustable aluminum upper a-arms with hinge pins 102 grams
wheel/tire combos:
Chrome XTM Pentos w/The Meats approx. 7 1/8" dia 4" width 506 grams
Stock wheel/tire approx. 6 3/4" dia 4" width 455 grams
pro-line 23 mm velocity wheel/40 series bowtie approx. 5 1/2" dia 3 1/2" width 245 grams
Pro-line 223 mm velocity wheel/moab 40 series tire approx. 6 3/4" dia 3 7/8" width 420 grams
stock center skid,lower 46.25 grams
Losi Hi Perf center skid,lower 52.5 grams
stock bottom end skid 31 grams
hi perf front skid 39 grams
hi perf rear skid 31 grams
stock top plate end 21 grams
hi perf CF top plate end 12 grams
stock upper chassis plate 129 grams
Hi perf CF upper chassis plate 73 grams
stock chassis braces 39 grams
hi perf engine mounts 26 grams
stock diff plastic cover 121 grams
vertigo lockers in aluminum diff covers 111 grams
stock cvd/axle 34 grams
MIP CVD assembly 34 grams
stock axle w/nut 12 grams
stock 2 speed plastic inc shaft 82 grams
ti-nitride steel 2 speed inc shaft ??
5 cell 2/3 A 1100 nimh pack 100 grams
Team Helotes 5 cell 2400 AA nimh pack 149 grams
Stock LST body 128 grams
CP2 body painted 2 coats trimmed 223 grams
wheel/tire combos:
TX
RE: Various and sundry weights
Looking at your numbers I would say that the HP plates are as heavy on the bottom and lighter for the top ones. This seems good to me.
CA
ORIGINAL: 2DMaxLST!!
Yep.I'm sorta stuck right now assembly wise waiting for a forgotten part but the chassis feels lighter and more rigid in my hands.Now if my motor would just get here ........
TX
Yes, that is my only battery and it is 1200mah. I am considering getting one more of them to use for the mains only.
Some more weights...
All HP chassis parts...
All Stock parts...
Here is why I had to expidite the installation of these parts...
All Stock parts...
CA
You will need two of these.
Peace [8D]
TX
I was making a guess, but I know it was not clear for me that I needed to order two of those and I could see that happening to someone!!
TX
Here's a link to a nice picture of the topside of a LST with the HP chassis conversion.
[link=http://www.dennisnadams.com/tmaxx/LST/carbon_chassis.JPG]Picture: Losi LST HP chassis[/link]
