Help..you know that sticky about the washer?
It was inevitable it was going to happen. I didn't think it would with only ½ gallon though it....Need some assistance though...
To cut a long story short it all happened when I blew a Glow Plug. Put a new one in and went to turn it over. Shazaammm. Crank wouldn't turn. On investigation this is what I saw...
First pic shows the head taken off. Upon investigation there appears to be no real damage to the lining of the Barrel. This is good news. Second Pic shows the conrod. Loads of swarf in here, washer missing...if it had one...and a build up in the conrod channel. Third pic shows what I believe to be the washer. How can I get this out without further damage. I beleive if I can get it out I'll be extremely lucky. Also, how do I take the flywheel off? Do I need a pulley?
I also discovered that one of the clutch springs had broken! Now I have those bits!...hehe...
Help guyz please...
Help guyz please...
RE: Help..you know that sticky about the washer?
Bad luck...Telephone Ryan at Helger distrubrution 01279641097 and he will fix it under warrenty. mine went just like yours full of metal particles.. got it back in 3 days
i fitted alu clutch shoes with mugan 1.0 springs. imo seem very good and no trouble since
CA
[:@] Leave the flywheel on for now.Use it to turn the engine clockwise as you're looking at it from the front and hopefully the piece of the washer that's wedged in there comes loose and didn't do too much damage.
That or don't touch it and send it to Horizon for warranty, they should cover that IMHO.
Mr impatient they call me. Anyway, I was able to free it without any further damage. I have the conrod out and the piston. I'll post a pic of the piston and perhaps you guyz can tell me if putting this back in will be okay. Or should I just speak to Ryan? I might do that if I'm honest and send it back tomorrow....I know a lot more about the engine now though...lol
On reflection and looking at the pic it's not good. I'm gunna send it back to Helger. Why should I bodge it. Just cos it works for Dynamite doesn't mean it works for me. Anyway, the other Mach .26 engine should arrive from the states in a couple of days. Back to running in again....
ORIGINAL: savagebeatlosi
IMHO I rekon you should buy a 'savage' and be done with it! HeHe.
SkipRat.
SkipRat.
Where were you racing?
Racing your brother OR at Eggy Primary School?
Heard it's reasonable there?
Indeed dodgey geezer!
SkipRat
SkipRat
SkipRat
SkipRat
ORIGINAL: seve
There are obvious scars on that piston i would definately send that back......
And take the bloody washer out next time.............
what he said, send it back, [echo] take the bloody washer out next time [/echo]
your lucky anyway! mine totaly blew up and broke the conroad, big chunks of metal everywhere, yours only has scratches, would probably still run!
Thats what I was thinking to I put it back together and let it run as is. But I've decided against it. Ah well, no LST for a while. The washers coming out on the forthcoming engine.
NEW to LST, I have reviewed all the remarks about the (WASHER). I can not find the sticky on this that is suppose to be at top of page, how do you remove the washer with out damaging the engine? Thank You[sm=confused.gif]
Go to the front page on the Losi and look UP! Its the first thread
http://www.rcuniverse.com/forum/REMO...2391794/tm.htm
Spoke to Ryan today. He's heard it all before. Anyway, sending the engine back tomorrow so post pending I should get a replacement for Friday. Nice.
ORIGINAL: LST-UK
And repeat after me..." I must take washer out ".......
