Is this right?
Is this right?
First off......Cheers to everyone for all the great info on the LST. I just got mine fitted with aluminum diff cases. The problem ( I think) is that the drive shafts barely go into the cups that are on the tranny. They fit into the cup, but are at the very edge of it.
Am I making any sense?
Is this normal for drive shaft setup? I would have figured that the shafts (or bones, cvds, whatever) would extend farther into the drive cups.
Any input would be great!
Thanks!
Jeff
Thanks!
Jeff
CA
RE: Is this right?
No that's the way they sit.I pondered why until I tried to remove my transmission and found that if they were any longer it would take far more disassembly to remove it. 5 gallons through mine and they show no unusual signs of wear or splitting yet
Hope this helps
Peace [8D]
Hope this helps
Peace [8D]
RE: Is this right?
Thanks for the replys guys. That's good to know. I just thought I had screwed something up already...
It just looks like any type of chassis flex and there gonna pop right out!! Well i'll give it a good bashing and see!
Once again...thanks!
Jeff
Jeff
