About what serial number did they remove the rotostart washer?
CA
I have serial number 11766 and am curious about the dreaded washer on the back of the crank. I have 5 tanks through it now so the washer is probably destroyed if it is still in there. I don't really want to take it apart if it is not necessary. When I do, I want to replace the screws with socket head screws. Thanks in advance.
MI
RE: About what serial number did they remove the rotostart washer?
I have read that the cut-off for the washer was serial number 11000. You may be in the clear. Good Luck!!
