glow plug and fuel
glow plug and fuel
hi there
as time passes i am no too far from having my lst, i am going to use byron 20% fuel with an os#8 plug, what do you think about this??
what fuel and glow plugs are you using??
RE: glow plug and fuel
another question, how long does a glow plug last?? i am planning to order 12 so with that cantity i would not have to order any more glow plugs, or do you think that 12 is too much
ON, CANADA
12 isn't too many, if you want to store them for a while. If you run your engine too lean, your going to need 24
What other plug should you use whn it's under 40 degrees?
i think that after reading these forums for such a long time, hopefully ill make a good job tunning the engine and not burning many glow plugs. here in bolivia one os8 plug costs $10 thats not fair
VA
I typically run Trinity 20% with McCoy 59 plug. I bought a gallon of the White Lightning 20% and will start running that with the McCoy 59 plug.
Anybody have experience with the White Lightning 20%?
Banned
ON, CANADA
I'm on my first gallon of white lighting 20% and its the BEST nitro I have tried, Its very Good seems like a New Truck with More Power now.
O-Yea ,I use OS #8 plugs and they last for a long time and the LST Runs Great .
CA
I use an Enya #3 which is the heat equivalent to an OS#8. However, in my heli's, the Enya will far and away outlast my OS plugs so that is how I got into Enya plugs........I can get a few MONTHS out a glow plug in my helis.
sorry for this stupid question(i have no experience with nitro rc) how long does a full tank on the lst last??
sorry i have no experience
ORIGINAL: chris89
ORIGINAL: chris89
Here an OS 8 glow plug cost $10 too, but later i found them for only $3.57 each at shopping.rcmodels.com.hk
