Need help with tunning my engine on new LST
It seems like the engine is screaming with high rev but with slow speed even I am on the high speed setting, what give? thanks
RE: Need help with tunning my engine on new LST
But I have already turn it in 3/4 till the spring is compress.....should I keep turn it in until the engine running better or is there anything else I need to adjust????
sometimes the plastic clutch shoes will freeze to the fly wheel......should come loose with a few short bursts...if not I would look at the shoes.
