LST Diff cover questions
MI
Okay guys, i see a lot of talk in this forum about the stock diff cases. The question i have is are you guys talking about the outer plastic cover i can see through the bulkheads, or are you talking about the actual diff cups inside the outer housings i can see through the bulkheads? I am trying to bulletroof my new LST i got last thursday (it hasnt even smelled nitro yet, its still really cold here in michigan). Any help would be great.
PA
RE: LST Diff cover questions
In regards to the alum upgrade of diff cases, most people are talking about the outer plastic case. It breaks very very easily. Some people have talked about upgrading their inner case (the one with the spider gears inside where you can put silicone), but upgrading that case is much rarer and probably unnecessary.
ON, CANADA
Here or here
http://www.killerhobbies.com/Browse_...hed_-_Losi_LST
http://nitrohouse.com/options,_lst.htm
Hope this helps
Hope this helps
I went with the plan LST ones, no problems. Just watch your shimming, I had to put the shim on the other side and all is ok. I found it easy to do the entire job with the truck upside down, the LST cases do not have the TOP marking so be sure you put your new ones in the same way you take the old ones out. I didn’t with the rear and had to pull it all apart again.
Sitting the he shelf at your local hobby shop with the original Losi seal still intact is the closest you will ever get to having it bulletproof [:@]but never mind they are exciting to break and cheap to fix.
ORIGINAL: [email protected]
How do you brake the cases? I've been running my LST up and over anything i can find with no problem? All i can think is that if you apply max brake at high speeds it might crack the casing. Any thoughts? Thanks!
I broke the rear diff case landing uder power after a back flip, to much shock to the system, my fault but did look cool.
