How do you hop up the Lst?
I am just curious as how to hop up the lst and which upgrades would be good to get. I have read many threads/posts about different parts but I am I am not to clear on what would be good upgrades, I already know about the diff cases and I have a set of them on the way. I really appreciate any help you guys(the "experts") can give me(a newbie).
Thanks in advance.
Thanks in advance.
ON, CANADA
RE: How do you hop up the Lst?
Well here are "The Essentials"
okay. so The Essentials include a few things to make your new LST bashworthy.
1. Aluminum diff. cases, from killerhobbies.com or nitrohouse.com - $15 - http://www.killerhobbies.com/Browse_..._Case_Polished
2. A good Rx pack. Recommended from onlybatterypacks.com, either the single 1200 mah pack for $18, or the double 2400 mah for $40 - http://www.onlybatterypacks.com/items.asp?db=24
3. the e-bay aluminum secondary gear cover - $15 - http://search.ebay.com/Losi-LST-Alum...jsZ1QQfromZR40
4. A good charger, unless you have one -the one I recommed - $50 - http://www2.towerhobbies.com/cgi-bin...?&I=LXCLD5&P=0, you can also use the vision peak 2, many people like this one. - $40 - http://www.rcmodels.com/rc-dyn-4044.html
5. Fail Safe - I recommend OFNA mini - $25 - http://www2.towerhobbies.com/cgi-bin...&I=LXEYG2&P=ML
6. Better Hex Drivers - $12 - http://www2.towerhobbies.com/cgi-bin...R0202&C=RALDTX - on this page you'll find a whole bunch of drivers, but look for the SAE sized Presicion Ball Hex Drivers, there will be 4. - .5", 1/16", 5/64", 3/32".
In addition, you might also want the CNR Aluminum Drive Hexes - $15 - http://www.crazynutracing.com/produc...2f32e3e9219f2e
Then you might also want the New Era Models roll bar, whick you mentioned earlier, some silicone diff grease - most people like 30k front, 50k rear.
That's about it.
That's what most people do, and is highly recommended but us "the "experts""
Hope this Helps!
That's about it.
Hope this Helps!
