CA glue vs Tire glue
IS there a difference between the two? I have CA and need to glue my new brt1 to the xtm gun metal pentos, should i wait and just get some tire glue?
RE: CA glue vs Tire glue
What are you using for inserts? I found that the stock foam inserts to be too soft, and the sidewalls are just plain weak! My LHS only carries the multi-stage inserts for 40 series size tires...
UT
I have been using DURO Super Glue. [&:] Seems to work well and it is thin. Just make sure that you don't try to use the Gel stuff. Too thik.
