4 wheel steering?
4 wheel steering?
I would like to know how to add rear whell steering. I see the spot for the servo... If you have seen a website or you did it yourself please post. I would like to do it my self, any comments would be great. [8D] Thanks
RE: 4 wheel steering?
You need parts numbers B2102 (steering bellcranks, shafts and chassis braces) and B4201 (steering hardware set), and a servo and a "Y" connector.
You have to install all the steering parts (mentioned above) on the back of the truck, exactly like it is on the front of the truck. Then you have to flip the rear a-arms, knuckles, shocks, and turnbuckles so that the shocks are on the back of the truck instead of the inside of the truck (mirroring the front assembly). This will turn the rear turnbuckles into tie rods to be connected onto the bellcranks. Install the servo and hook up the linkage. Connect the rear servo to the front servos with the "Y"connector.
