LOSI LST VERSION TWO....
Is it true that losi are releasing a version two lst? I heard if via my local dealer, apparently he was saying the reason behind it is to do with the suspension arms. Apparently they were designed for use in hot weather i.e. california, and that when you use the truck in cold weather i.e. the uk they can brittle and break very easily.
So if this is correct when is it out?
kind regards
wayne
kind regards
wayne
RE: LOSI LST VERSION TWO....
That would be more plausable just upgrade the arms
ORIGINAL: ResB
Unlikely LOSi will bring a version 2 of the LST out just for that one item. Wouldn't they just upgrade the A-Arms?
ON, CANADA
ORIGINAL: mtdriver
ORIGINAL: ResB
PA
They will not change it until sales go down. Then they will make it a sport version or something like that with a few different but probably simple options. All companies do that to keep sales up.
Unless they come up with something revolutionary to change it soon, I think it will be a while.
