SH 28 clutch issue
NJ
SH 28 clutch issue
ok i think i'm having a problem with my clutch, because no matter how low i set the idle the truck still jerks forward, does anyone know what it might be? i checked my trims and idle and the engine is not set to lean and it's only on the 3rd tank of breakin
RE: SH 28 clutch issue
yeah most likely what these guys said, as a replacement i would suggest savage shoes and springs or mugen shoes and springs, but i would not recommend the ofna aluminium setup or replacing with the stock setup.
Skip the OFNA and go with either Nova or Mugen Aluminum shoes. If you want a higher/harder launch go with 1.1 mm springs if you want nearly stock rpm engagement, go with 1mm springs. With an SH, avoid the plastic Savage shoes like the plague! You'd roast 'em in a tank or 2. I've been running the Nova aluminum in my SH for just over 2 gallons and am very happy with them.
CA
oh man, i just installed a set of ofna's aluminum shoes. what's gonna happen? do they wear out fast, slip too much or eat my clutch bell and bearings?
