savage clutch SPRINGS question
NE
anyone running stock savage clutch spring???? if so when your truck idles and u pick it up do the wheels spin??? or do i have an air leak anyone have a picture of the stock flywheel against the crankcase???
TX
RE: savage clutch SPRINGS question
No pictures, sorry... But I have run the savage springs and found them to be better and last longer than stock springs. You may want to remove the clutch bell and double check that there is not a spring broken, odds are there is one broke, idle speed should not be so fast that it engages the clutch. Hope this helps....
PA
My tires will rotate slightly but not enough to cause any issues. I can still allow it to set at idle for several seconds with no bogging issues. We drop start where i race so it diesn't cause me any issues.
NE
its not to the point to where the truck moves it just when i pick the truck up the wheels spin but ill check to see if i broke a spring
