Basher
Basher
All you guys that run this thing hard. What do you think is needed before this truck is bash worthy?
I am trying to decide between this and the savage k4.6.
RE: Basher
RPM arms and Aluminum Diff Cases are all you need. The JR XS3 Sythesized radio that comes with the LST is a high end unit that seriously rocks!
I have both a Savage (SH 28) and the LST and I like the LST better...It is much easier to work on, much more raceable, much more tunable (suspension, transmission - comes with high/low & reverse all stock!). The LST has been as reliable a basher as my Savage with the 2 upgrades listed above.
RE: Basher
I like the idea of the savage because A i own one. B it does not come with a radio, I have a sensor and high end airtronic servos. I could always sell the xs3...
Are the servos the lst comes with digital?
UT
RE: Basher
ORIGINAL: Seiki
RE: Basher
If you already have a Savage, get the LST! The 4.6 isn't any different than your current savage (Other than the engine and a few mods - which can be upgraded/added to yours anyway).
Once you get the LST, you might even wonder why you have a Savage!
UT
RE: Basher
ORIGINAL: Nitronutt
That is exactly what I have been thinking after seeing a friend of mine bashing his stock .25 w/o any breaks..
RE: Basher
I am selling my current savage. Its all "jazzed up" and nice. I want to start over. I think the LST is my choice. I need a link to the stiffer springs by the way. Here is my list of things that will be orderd along with the lst
LST
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB0010
TiNi Gear set
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB3428
By the way is there a tini clutch bell?
TiNi Shock shafts
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB2841
Shock Bodys
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB2814
Alu diff cases
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB3532
RPM
http://www2.towerhobbies.com/cgi-bin...?&I=LXKJD5&P=7
Hexas
http://www2.towerhobbies.com/cgi-bin...&I=LXJGR4&P=ML
Wheels
http://www2.towerhobbies.com/cgi-bin...?&I=LXKSA5&P=7
Tires
http://www2.towerhobbies.com/cgi-bin...&I=LXJGS0&P=ML
Body
http://www2.towerhobbies.com/cgi-bin...&I=LXFSN0&P=ML
Turnbuckles
http://www2.towerhobbies.com/cgi-bin...?&I=LXHSV3&P=7
Thats it. For the servos. I will hop that area up when the stockers die. Engine when the mach dies i will see whats availible. I know horizon is steep if anyone know of a better site that carries the losi line up let me know. If i missed anything please let me know also. Thanks guys!
These the springs?
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB2952
LST
TiNi Gear set
TiNi Shock shafts
Shock Bodys
Alu diff cases
RPM
Hexas
Wheels
Tires
Body
Turnbuckles
These the springs?
Banned
ON, CANADA
RE: Basher
If I was Buying that Much Stuff,
I would Go on E-bay and you'll get Most of your list there New in Box for close to Half to ( 3/4s)the Price you'll Pay at any Hobby Shop.
RE: Basher
ORIGINAL: dOWa423
I hear that you do not want to run Digital servos in the LST. Mostly because the digital stuff sucks that batteries way fast. You can still use a super high torque servo that is not digital. They are still like $100.00 usually.
ORIGINAL: Seiki
CA
RE: Basher
After contact with J R Radios, they recommended the JRPSZ4800T. The T disignates"Torque". The reason for suggesting analog servo's is that they are more forgiving , as digital servo's would not be covered under warrenty if not set up properly. I think they were about $84.95 each as opposed to $114.94 ea for the Digital Z8800T servo's. DBM [8D][8D]
