Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
Enormous Cooling Head
Reply
Old 05-31-2005, 04:36 PM
truckstalk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Enormous Cooling Head
who tried this giant cooling head out? is it GOOD?
looks nice.
thanks for any info.
truckstalk is offline
Old 05-31-2005, 04:39 PM
truckstalk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enormous Cooling Head
BTW...how about the one made by NOVA RACING?
which one is bigger/better?
thanks.
Old 05-31-2005, 05:10 PM
biggdawg800
biggdawg800's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my brother put one of the enormus cooling heads from american cnc on a picco outlaw 26 and it dropped his temps 60-70 deg F. I have one I will be putting on my SH 28. I would highly recommend his stuff. my brother just got his tmaxx chassis too and it is top notch best i have seen.
biggdawg800 is offline
Old 05-31-2005, 05:58 PM
FORDMIKE65
FORDMIKE65's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Works great!! Dropped temps at least 60 deg on my Mach .26. I just got an SH .28 on sale at Hobby People yesterday.Do you think the head will fit it too? They look similar,same manufacturer, as I've heard on this forum.
FORDMIKE65 is offline
Old 05-31-2005, 08:05 PM
biggdawg800
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't think it is the same the 28 has a bigger bore. he makes a head for the 28 though.
http://www.acncm.com/detail.aspx?ID=49
on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Old 06-01-2005, 01:47 PM
truckstalk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
which one is bigger?
nova race head or enormous? thx
Old 06-01-2005, 01:57 PM
hobbyadict
hobbyadict's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
id watch it with the head just couse the head says ~210 with the head without the head you could really be running like ~300 degress[X(]
hobbyadict is offline
Old 06-01-2005, 03:20 PM
Bud Morrison
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah watch them bigger heads. While they do improve cooling and will allow for a leaner mixture. You have to keep a close eye on the core temp of the combustion chamber. The larger head can fool you into running a lean enough condition to damage the engine. While a hand held temp gauge may show a low head temp. You will want to get a temp probe that will get the temp at the glow plug way down in the hole.
Bud Morrison is offline
Old 06-02-2005, 12:22 AM
pointblank
pointblank's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might be getting a lower temp, but regardless the motor is still running lean. Tuning the engine isn't just about temps. I'd stick with stock or slightly larger than stock cooling heads.
pointblank is offline
Old 06-02-2005, 11:57 AM
biggdawg800
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The way we tuned my brothers was to get it running great with the stock head. then we switch to the enormus head and didn't tune it anymore just the occasional tune for temps. should be the best of both worlds that way.
Old 06-02-2005, 04:09 PM
RCtruckRacer
RCtruckRacer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought an oversized head from wakefly68 on eBay, so that I don't have to worry about engine temps when the ambient temperature is over 100. It's only slightly bigger than stock, and I think I paid aroun $25 for it. It lowered my temps around 20 degrees, should be perfect. Like the Biggdawg, I did not lean my engine out more after installing. If you are asking if you need this, I'd say only for bashing (especially if you are making a rock crawler - slower speeds & higer revs = higer temps), or if you are as crappy a racer as me and go too slow sometimes! [:@]
RCtruckRacer is offline
Old 06-02-2005, 10:14 PM
brandon17617
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a venom temp gauge, is that the best way to measure the temp of my motor? or should i use that temp gun with that laser thing? or is there another product out there that i should use? if someone knows of another temp gauge would someone please post a link?
brandon17617 is offline
Old 06-03-2005, 09:45 AM
kevinb456
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rm-rf
that doesnt matter - unless you tune your engine by temperature (which is just stupid) you shouldnt have a problem - always tune your engine by air/fuel mixture and how the engine reacts (sounc, acceleration, smoke etc). temperature should only play a very small part in tuning, dont rely on it too much.
kevinb456 is offline
Old 06-03-2005, 02:13 PM
Devilmanak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Definately! I used to go by the idea that the bigger the head, the better. NOT true. Unless yoiur particular engine is undercooled, then adding a huge head will just allow you to run too lean and do damage. A couple of examples would be:
1) TRX2.5 - Runs hot, but mostly due to other problems, such as carb leaks. The Nova head is really too much for it, it can lead to overleaning which in turn leads to HIGH temps. I fought this all last year. THe CNR "shortly" head is the one for this engine.
2) Force .25 - I put a Nova on this, and was able to lean out and get a PILE more power. It worked GREAT for bashing, but once I had to use it on the track in a buggy one day, I started to burn plugs due to a lean condition.
Some engines just do NOT need it! (RB's, for example.)
Temping further down the hole makes no difference either, the oversized head is still cooling the entire engine, not just the head itself.
It's allabout the smoke trail, as was just said. I rarely temp my RB's, Novarossi's, etc., any more, just at the end of the tank to put a grin on my face. (I love seeing 210 after a full tank of racing hard!) Tuning by smoketrail is different for each engine, but once you get yours figured out, it is a very reliable way to tune an engine.
Devilmanak is offline
Old 06-03-2005, 02:24 PM
kevinb456
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"head will just allow you to run too lean and do damage"
as i said!!!! this doesnt make the head a disadvantage - it only allows you to lean the engine while maintaining the same temp. but you should tune an engine on air/fuel mixture - so just because the temp is lower doesnt mean you can lean it. aslong as you tune properly, a bigger head is always a good thing (unless it gets <190F or so! then its just not hot enough for the metals to expand properly)
Old 06-14-2005, 11:38 AM
MrBillUp
MrBillUp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://i5.photobucket.com/albums/y15...p/MVC-719F.jpg
http://i5.photobucket.com/albums/y15...p/MVC-717F.jpg
http://i5.photobucket.com/albums/y15...p/MVC-718F.jpg
A few pics of the Enormous Cooling head from http://www.acncm.com/detail.aspx?ID=36
It's not a big as I thought but it is alot thinner than the stock head which will allow the heat to dissipate a hell of alot quicker!
http://i5.photobucket.com/albums/y15...p/MVC-721F.jpg
Another added with the body on!
MrBillUp is offline
Old 06-14-2005, 12:05 PM
Bud Morrison
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put one of the nova cooling heads on mine. Does a much better job than the stock head. Im down to 185 degrees at tune.
Old 06-14-2005, 05:30 PM
kevinb456
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im up at 270F with nova head - and im not running lean, this is one hot engine [X(]
Old 06-14-2005, 07:02 PM
hobbyadict
hobbyadict's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mrbillup have u run the engine yet???? i i where u id move the airfilter thats REALL close to the engine!!!!
use a Traxxas exhaust coupler! from the sounds of someone thats has it it works great!!!!
Old 06-14-2005, 07:11 PM
MrBillUp
MrBillUp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: hobbyadict
I have'nt run the engine yet no! I need to go back to stock settings and re-tune to 220F if I can, then fine tune. I run the air filter the other way, I turned it 180 deg for the photo's sake. I will be getting the Savage 2.5 Motor Saver as soon as I can afford it!
I must say that now it is on the mach it is collosal and these are very very well made and has very thin fins so a Roll bar is a must.
MrBillUp is offline
Old 06-14-2005, 10:11 PM
Bud Morrison
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kevinb456
Do you have the center of your windshield cut out ?
Old 06-14-2005, 10:24 PM
FORDMIKE65
FORDMIKE65's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5981345500&ssPageName=STRK:MEWA:IT[/link]
Is this "cool" or what!!
Old 06-14-2005, 10:40 PM
SublimeJason
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: FORDMIKE65
Hope this works.Is this "cool" or what!!
That dose Look Cool,It looks like it could work?
SublimeJason is offline
Old 06-14-2005, 10:56 PM
FORDMIKE65
FORDMIKE65's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seems to have a pump,reservoir,radiator & a water-cooled head like used on marine engines.Pretty cool,but must add some weight to an r/c truck.I might ask the guy a few ?'s and ask for some more pictures.I like it! Would make a nitro truck even more realistic.I wonder if the water pump is a small electric motor or is driven by the engine?
Old 06-15-2005, 06:16 AM
Bud Morrison
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Systems like that have been around for awhile. The pump is a lil vacume powered diaphram pump ran from the pulse from a line from the crankcase or intake of the engine. Someone awhile back was making a nicer looking system that had a lil aluminum radiator. The system he is selling there looks a lil barbaric as far as the radiator and tank is concerned.
Contact Us Archive Advertising Cookie Policy
