Can you use an air compressor.........
Can you use an air compressor from a nail gun?
My dad has one and I would like to use it with an airbrush.
If it can be used what other equipment will I need? (I don’t have any thing except the compressor)
thanks for the info.
RE: Can you use an air compressor.........
Yes you can use a any compressor that can push 40 PSI or more. If yours does nailguns it probly does at least 100. If you just have a compressor then you will need: a pressure regulator, A moisture trap/ filter, and a fitting that will adapt the hose to your airbrush hose. (most brush kits come with a fitting like this). get that stuff and some teflon tape tape for the seals and you should be fine.
