DiFF CASE
Banned
ON, CANADA
RE: DiFF CASE
ORIGINAL: BLUERACER
has anyone had a problem when chaning over to the Alum Diff Case? I have two and they both fit very tight
Hope thats some Help.
CA
RE: DiFF CASE
Since you have the blue painted diff cases, you might want to clean all the excess paint from the inside were the bearings will sit in the case. If you remove the shims completely, after the paint wears away(from normal running) it may cause the excessive backlash in the ring and pinion and eventually damage the gears.
