Different tire weights and sizes
AL
I just weighed and measured the following tires and wheels for your viewing pleasure:
Losi Claw tires mounted on Magneto wheels 15.7 ounces 6.75 inches
XTM Meats on Pentos wheels 17.7 ounces 7 inches
Losi Super King Pins 9.5 ounces 6.75 inches
HPI Dirt Bonz 6.3 ounces 5.75 inches
Losi Zombie 8.9 ounces 5.75 inches
Pro-Line Masher 40 Series 10.3 ounces 6.25 inches
Pro-Line Dirt Hawg 40 Series 10 ounces 6.25 inches
Pro-Line Big Joes 40 Series 10.9 ounces 6 inches
Pro-Line MOAB 12.7 ounces 6.75 inches
Panther Python 7.8 ounces 5.75 inches
Pro-Line Bow Tie 40 Series 6.3 ounces 5.75 inches
Losi Magneto 3.2 ounces
Maximizer beadlock 4 ounces
Pro-Line Dish 40 Series 3.2 ounces
RPM Monster Clawz 1.7 ounces
_____________________________
Check out www.killerhobbies.com Monster trucks, parts, & accessories.
UT
RE: Different tire weights and sizes
Here are some visual pics of the difference between the height of the:
Proline 40 series Big Joes on Mambos
Stock LST
XTM Large Series BRT1's on Pentos
Hot Bodies Revolutions on Pshyco's? I think
(left to right)
and now the width:
(right to left) [&:]
[sm=bananahead.gif]
Stock LST
(left to right)
and now the width:
[sm=bananahead.gif]
FL
Did you get the weight of the hot bodies?I have a similar set with the flame treads and I know those puppies are over a pound each.
AL
I don't have any Hot Bodies tires in stock or I would have weighed them.
Thanks for the info Brushless and Dowa, that was just what I was looking for.
Are the rim's about the same size? I'm wondering since the wheels have different widths? Do they glue up ok if some wheels are 6 and 3/4", while other's are 6 and 1/4", 6" and the 40 series are 5 and 3/4"? I guess the wider wheels just "bulge" out a little more with the narrower wheels? I'm assuming the 40 series are a whole different ball game anyways. Thanks[8D]
ORIGINAL: brushless
Hi,
That's mean, I can use serie40 from PROLINE with the LOSI Zombie tires ?
I'm 90% sure I made a mistake, where qhould I put the 5.75 inches
Are the stock hex's really a weak point? I think this is why Pro-Line made their 23mm adaptors?So in searching for tire/wheel options for my truck, i'm wondering if I should invest in another Losi wheel or go straight to the Pro-Line set-up? Any suggestions?
I've been told the T-Maxx rims fit the LST hex. Is this a good option?
I don't mind those 40 series tires, it's just these MT wheels and tires are a decent size investment. Maybe the Bow Ties or Panther Pythons?
Thanks[8D]
Thanks[8D]
