lower lst, stiffer springs???
Hi,
Has anyone tried putting shock Limiters (Eg. fuel tube or such inside the shock on the shaft) to limit the shock travel so you can load up the springs either with spacers or the threaded shock adjusters but still keep the trucks centre of gravity nice and low and not bottom out over jumps as much. ive been toying with the idea instead of just putting heavy springs in and taking out the preload spacers (thought this might be a bit of a bouncy way to go). Anyones thoughts or experiences would be greatfully accepted.
Cheers
John
