LST Setup
LST Setup
Is there a place with setup sheets for the LST? How would you set up your LST on a fairly tight dirt course? The dirt is not loose, it is sprayed with water so it is packed down.
TX
RE: LST Setup
none that I know of, But for packed dirt I would run bowties for tires and stiff springs (no spacers). and depending on the jumps and curves anywhere 45wt. to 65wt. shock oil.
RE: LST Setup
40 series bow ties are your best bet on a hard clay surface. I run near the same setup as The Drake - check out [link=http://www.thedrake.net/]The Drake[/link]
hope I don't get in trouble for that too...
