Slipper clutch adjustment
Could someone explain where and how to adjust the slipper clutch? I have looked in the manual and the picture isn't much help. Is it the 1/4" nut on the end of the shaft that the gears go on? I need the Dick and Jane version with pictures.[sm=bananahead.gif]
RE: Slipper clutch adjustment
If I run mine at 1 turn out its a little too tight, I can't keep the front end down. Its currently set about 1/16-1/8 out from a full turn, I can control the truck now.
