View Poll Results: A poll
Voters: 27. You may not vote on this poll
MY LST
NY
MY LST
MY LST
just showing my lst
oryginal first 2nd and last body
my painting sux, worst thing u can do is ruch never rush
my ups
on road tires
bigger fuel tank
alu clutch
alu hex hubs
SH .28 engine ([email protected])
3 new bodies
secondary gear cover
shock springs rated 8.8 lbs
rear alu blue diff case
and my question will engine runs hot if i wont cut any holes in body ?? (f-150)
tnx for looking
just showing my lst
my ups
on road tires
bigger fuel tank
alu clutch
alu hex hubs
3 new bodies
tnx for looking
RE: MY LST
No holes at all will cause the engine to run hotter, if not overheat. Just put a nice size hole in the middle of the front windshield, and then cut out a hole for you engine, and gas tank, and it will run cool. You could also help it by putting some holes in the side windows and such, but really isnt nessasary. Overal, I like it, simple, yet the truck still looks good.
NY
RE: MY LST
i know i cutted in oryginal body whole front windshield, and i hate holes in front windshield, but i just made 2 bodies crowd pleazard and f-150 and i dont wanna cut, u think even in this weather it will get to hot ??
RE: MY LST
I mean if could go either way. The weather outside is getting cold, and will let the engine run cooler, but I just never gave the body holes a second thought. I dont think it would cause a problem to at least try it out. Run a tank through it, and see how it runs, and the temp of it, and go from there. At least this way you'll know for sure if you can get away with no holes in the body.
NY
RE: MY LST
why wrong ?? i got same at back but crash with garbage can took 1and crash with jato took 2nd its make him harder and i c better when bashing
(front red back blue) only thing i would change put heavier alu 1s on front but now they r broken
NY
RE: MY LST
wow i just putted new 8.8lbs rates springs on my shox wow, they need spacers, cause without they touching ground with kind of light push down, but with spacers wow looks like what can 1/2 inch spacer can do ? wow alot - they nice working, i cant wait to test in terrain
