Is this grease okay??
FL
Well i finally changed my diff cases to alloy and i took the time to change my diff fluid to 50k but i also heard that i needed grease for the out side of the diff i bought some grease but i aint sure if its good, its real thick and red does it matter? here are some pictures. Thanks SOULJA
CA
RE: Is this grease okay??
I bought that same grease for my 1978 Bronco. I lubed every U-joint, drive shaft and linkage on the truck and I still had half a can left over...That stuff lasts forever. Now that you mention it, I'll use it on my LST.
FL
Well i just used it and man its real good after changing my diff fluid and greasing the inner casing my lst feels better wow what a difference[8D]
To actually answer your question, yes, that grease is perfect. I use the synthetic version for EVERYTHING (ATV, LST, wherever needed). I also added some to my tranny a few gallons ago.
