Black Losi Springs, Oil weight...
RE: Black Losi Springs, Oil weight...
Ken, just wondering if you had checked to see if they were mounted backwards yet and that was the problem? I think this may be the cause of several bad steering reports.
Ed M.
Ed M.
MI
nope, I have never changed the carriers. Good thought (and tip) though. I changed the front shocks to silver springs and went down to 20wt oil. It seemed to work good. So now I am running Black with 30wt in Rear with thin swaybar. Silver with 20wt in front with no swayber and 30K front and rear.
My Feedback: (9)
CT
ORIGINAL: bentgear
Ed M.
Ed M.
claudacio, if you ever need to reverse them on purpose then you may have to do a little light grinding with a Dremmel for clearance.
Ken, glad you got it worked out. You might try moving the sway bar links in on the sway bar and if this makes it more to your likeing then try the thicker sway bar.
Ed M.
Ed M.
