mach 26 rebuild question
on the connecting rod there is a small oil hole that lubricates the bushing that connects the con-rod to the crank shaft.
I forgot to note the orientation of the hole (facing into the engine or towards the back plate) when disassembling
the engine. The exploded view on the back of the manual shows the con-rod but unfortunately not in detail enough to see the oil hole.
Any help on this one
