LOS2 Lean Engine
LOS2 Lean Engine
Love the LST2, had serious leaning issues. Filter routed directly behind engine at combustion area. Heat evaporated fuel in filter. Rerouted fuel line around back of tank. Problem solved. Anyone else with this problem on the Mach 427???
RE: LOS2 Lean Engine
Lay off Mike, it's his first post. If no one asked questions on here it wouldn't be a discussion forum would it? This isn't a search site, it's a discussion site. Just because you're annoyed by questions that are far below your knowlegde of the hobby doesn't mean you have to belittle everyone who asks a question. Like your momma may (or may not) have told you, "if you have nothing nice to say, don't say anything".
MI
ORIGINAL: TeamLosiFan
Plus, everytime i join a new message board, the first thing i do is search for whatever it is that i am looking for, because more than likely it has been discussed into the ground already.
