Life of fuel
RE: Life of fuel
If its stored correctly (room temps and sealed tightly) it should last a pretty long time. I'm not sure on an exact timespan, but I'd say it would last a while.
CT
RE: Life of fuel
i had plane fuel last 4 months after opening it car fuel goes as fast as i get it. you can tell when it starts to go bad ,the fuel will discolor from sunlight if it has a color to it or it will evaporate or condensation will occure inside the gallon. i usually mark the gallon with a perminent marker and if the level falls below that mark it either leaked out or the seal went bad and evaporated. when that happens its done and you need a fresh bach.
