aftershock slipping
NJ
aftershock slipping
I read all the posts about the 2 speed o.w.b. I cleaned mine and its better. but thats not the major problem. The truck drives like it is stuck in 2nd gear. the clutch bell is colored from the heat and the truck does not roll backwards. The wheels are locked. If you force it, it will let lose, then it will be back in first gear for one shift and then the same thing. This is only on 3 tanks of gas, one was idling. I had to clean the o.w.b just to get the truck to move at all. I got the truck 2 weeks ago, and only idled through a tank then I tried to drive it and it didn't move. Took a new truck apart to fix it, then tried it today again. Any help?
CA
RE: aftershock slipping
My Aftershock did that for about 15 tanks............ then in was fine..................... I'm on my third gallon and hasn't happened since
