STS 30?
CA
RE: STS 30?
I have not had much success changing pipes. Never seemed to me to make as much difference as others sometimes report about the STS 30.
I have found effort put into the carb is much more worthwhile. Sometimes changing the O rings helps, sometimes the teflon tape on threads of the LSN.
I have used a Novarossi carb with complete success, and also a carb off the Savage K engine. The K engine carbs are sold new at Tower Hobbies for around $50.00.
Good luck, this is a great engine when you have it working right, but the carb just is the "nuts"
Dennis
Dennis
RE: STS 30?
i pulled the needles out yesterday and i looked at the o rings and they looked fine i havent run it since then because of the weather. i cleaned out the carb and blew some compressed air through it to make sure it was clean so i hoped that fixed it and if it doesnt im going to buy the sts pipe.
MI
RE: STS 30?
Don't worry about the pipe, I've never run the STS pipe on mine and it runs great.
I know your O-rings looked fine, mine did too, but they are the problem. A little pipe tape on the threads of the LSN helps, but the HPI S-25 carb o-rings and some green slime on them completely cured my changing tune. They are a tight fit, but a ton cheaper than that new pipe.
#32
MI
RE: STS 30?
ORIGINAL: kraffty
How about longevity...ive got 2 motor now that are worn after 3 gallons together.I need power and one that will last.
Alot of people are seeing failures after only a few gallons. Mine is over 8 and fine, but aparently that is not the norm. I would look into a Mach 427, LRP Spec 3, or Nova Rossi, depending on your budget.
#35
RE: STS 30?
why did you have to do that? i can do that with mine tho its a truggy motor witch is in the losi muggy it rips and the motor may have lower compression but i got a hot plug and it starts easyer than ever. im using the mc59 now and its working awesome
