Gear Question
Gear Question
When you pull your transmission out of the LST should the gear closes to the transmission box spin freely?
Mine his little friction and does not turn the shaft.
IN
RE: Gear Question
If it spins freely counter clockwise (same direction the engine turns) than your good. When turned clockwise the tires sould move. You said it had a little friction, try cleaning the one way bearing and the put a couple of drops of oil on it. That should take care of the friction.
