LST2 or Muggy
RE: LST2 or Muggy
ORIGINAL: Broke it again
Can someone point out the pros and cons from the LST2 and the Muggy? Thanks.
You cant go wrong with either, just dont get anything Traxxas again and you'll be fine
RE: LST2 or Muggy
depends on what you want it for. for bashing the lst2 is a great choice for me does everything i want and more and is a solid truck. i was going to get a muggy first then i heard about the clutches being bad and people having trouble right out of the box so i ended up buying a lst2 and im glad i did.
RE: LST2 or Muggy
ORIGINAL: sfar785
Huge Con for the Muggy...it eats clutches...i've gone through 4 in 2 gallons of fuel...
Even if you have clutch problems, a simple vented clutch bell will hopefully sort it out.
FL
RE: LST2 or Muggy
i wasn't going to get the muggy because of the clutch issue but i said screw it and got it i put a 12t vented bell on it dynamite shoes almost 2 gallons little wear on the clutch and i am still running the 420's
CO
RE: LST2 or Muggy
Great input guys. Thanks. I am leaning towards 1 LST2 and 1 Savage. Can anyone direct me to a site that has good looking aftermarket wheels for the LST2? Also, do the proline bodies fit on the LST2 with a little mod? I want to use the F-650 Ford body and the Hum-Vee bodies.
GA
RE: LST2 or Muggy
The LST was teh original Team Losi monster truck. Very successful and had great handling characteristics.
Losi listened to what broke or was troublesome on the original, and fixed it on teh LST2!
The Aftershock is closer to the orig LST, with several improvements added, but w/o reverse, and teh hi/lo range tranny.
