what is the cause of the muggy clutch ?
hi
i'm thinking of getting a losi muggy but i have read so many problems with the clutch seizing up what is the cause of the problem and what is the best way to fix it
RE: what is the cause of the muggy clutch ?
its because losi geared it to the moon. (also a lil chasis flex) get a maxx life clutch and a 12t vented clutch bell
NJ
i have a custom chassis brace and a cented cb which makes the shoe last a lot longer....... the reason the shoes go is because the chassis flexes and then the bearing in the clutch go which causes the cb to move and that makes the shoes wear out fast....really fast........so my chassis brace solves that problem ........... and i run a 13t vented cb......
he made it, just get some aluminum angle bar, cut to length, few holes in it and corresponding ones in the chassis and you are done
NJ
ORIGINAL: ross_jsy
