cv joint
IL
cv joint
Hey everyone,
I have as Losi LST 2. I was wondering if anyone has had problems with the cv joint pulling out of the center diif. cups. I have had this problem since day 1 with the LST 2. The truck is awesome except for the cv problem.
If anyone has had this problem what have they done to correct the problem.
ON, CANADA
RE: cv joint
Check to see if you have a Broken Diff Ring, This Piece and you can Pull the Out put shafts on the Tranny a mm or 2 (Be sure to line them up on the Flat spot and Use loctite)
IL
RE: cv joint
I have lined them up and loctited the set screw on the diff so that it does not come lose. However I will check the part you mentioned and see if it is broken or not.
Thanks for you input.\
