muggys screwed up
FL
muggys screwed up
every time i gas the throttle my steering twitches really bad to the point where i have no control over it and it drives where it wants to drive but my throttle servo works fine. anyone know why this is happening
PA
RE: muggys screwed up
my LST2 was doing that, it was because the throttle servo was less powerful so it used less power, but my metal geared servos used alot of electricity, so they didn't work, and the low-power nylon geared servos did work. my battery was bad. yours may be too.
that LST2 is now a Muggy with an OFNA 1600 battery
FL
funny thing is when the truck is off worls perfectly but it only does it when the engine running at ilde the front tires will be striaght but any gas the front end starts turning which ever way the want
FL
oh yea i have a hg645 servo for the steering and used one of the old JR steering servos for the throttle now so that could maybe be using to much power maybe
PA
that was when it started with mine actually, i had a Z650 in my throttle, and the F/R servo worked but the others didn't, try using a spare battery or bring it to your local hobby shop, they'll let you test out a spare. Or if you have the AA battery adapter that came with the JR system, try that.
maybe the Hitec servo requires more power than the Z590 on your throttle?
hope this info helps,
Derek
Derek
PA
it says 92% of teens have switched to rap music if you are the other 8% put this in your sig
your a teenager right? i'm 14 how old are you?
RI
ORIGINAL: roweder
As far as the servo glitching goes it sounds like you have interference...makes sure the servo wires are not near any metal parts..use heat shrink tubing around all wires to help insulate. Some times when the engine runs they can cause interference...not sure why but I think maybe they create some type of magnetic charge.
PA
ORIGINAL: SOILWORK
My user name says it all
ORIGINAL: roweder
PA
ORIGINAL: roweder
it could be interference if it doesn't do that when the engine's stopped, do you still have the stock AM radio? switching to DSM would be really expensive, so let's hope it's the battery
ORIGINAL: SOILWORK
ORIGINAL: roweder
RI
Not sure, I had the same problem with my TNX, The servo would twitch when the engine is running and it would stop when the engine is off, It could be that when the engine is running, there is just enough of vibration to move the wires a liitle causing the servo to glitch. I insulated all the wires with heat shrink and the problem stopped.
FL
well did some testing on it the battery is not bad but now it will twitch with the engine off. i will steer it with the transmitter and lose steering out of it then get it back abd then when i tap on the radio tray it twitch really bad so took it to my lhs and they told me it was the receiver so it gets here wednesday so hope that fixes it
FL
put it today works like a champ took the old reciever apart when i crack it open sand just fell out of it so i quess i have to find a better way os sealing the reviever box but i quess my fualt
