Muggy aluminum bulkheads
RI
The screws in that hold the front and rear ends together are weak and always back out, does anyone make alloy bulkheads for the muggy. I know they make the pin plates in alloy but I have not seen the bulkheads...thanks
RI
RE: Muggy aluminum bulkheads
That's what I did, I used CA glue instead...My friend also has a Muggy and was asking about the alloy bulkheads, but I wasn't sure if they make them. Do you have a link To the LST bulkheads..thanks!
TX
DYN7207B are the blue dynamite version.
I would just replace the stock bulk heads and use brand new grade 12.9 hardware with shoe goo. If that did not work then I would buy new stock bulkheads and use 3mm grade 12.9 hardware. Those alum bulk heads are going to be a lot of weight.
