WHEELS WONT STOP TUUNING AT IDOL
Hi guys
Here is my problem i have changed my engine and clutch in my LST and now when i start it up the wheels start to spin some what fast before i even push on the throttle, i have tried all kinds of things but they still spin on me it's al;most like the cluch or the slipper are to tight, but i have tried to lossen them but still no change. Please can anyone help...
RE: WHEELS WONT STOP TUUNING AT IDOL
Thanks guys yes the clutch bell does spin freely and there are no srpings broke the engine and the clutch are brand new. i have been screwing around with the idol speed works a little slows it down but not all the way. any more suggestions.
hey man, I think I may have the answer for you. Did you keep the original collet that came with your original engine/output shaft? If you tried to use the new collet that came with the new engine it won't work without a lot of fiddling.
oh wait, I may of jumped the gun. yousaid the clutch bell spins freely? I'm guessing then it's just your tune. sorry for the confusion!
WA
ORIGINAL: Duratraxman1
I think it is normal to have them spin a little. How fast do the wheels spin?
FL
sure you are turning the idle. not the low speed. checked your throttle trim. Is the return spring pulling the slide back all the way.
CA
I have the same problem. I just finished replacing the owb but that was a different problem. But for my clutch always engauged problem, I took the clutch bell off and found the inner bearing felt rough, so I replaced both 5x10 bearings. It's pretty common for these to go bad after a gallon of fuel or so depending how hard you run. My run away truck got worse as it got hot. That's why I suspect those bearings. Also check your servo's for proper operation and posistion at idle. My run away truck repair isn't confirmed yet. But I'm pretty sure I got it, reason I'm confident is when I would roll the chassis across the ground looking for drivetrain binding I noticed the clutch bell was ringin. After the bearing replacement the ringin noise was gone. So this leads me to believe the bearing had a slip and stick condition. But hey I won't know till I run it, if it doesn't sit and idle I'll be posting with you! Hope this helps.
CA
Drove mine today and well there's still a problem[] I noticed during warm up it shifted into 2nd and did not go back into 1st. Upon slowing down I had to use my foot to stop it then it stalled and would not restart. Had to get the wheels off the ground to start. I tried reverse and low gear select on the trans but still moves on it's own. Not sure what I got here any ideas?
if when you try and start the engine, the wheels spin, then the drive is engaged via the clutchbell on the output shaft. Did you use the collet that came with the new or old engine?
Thanks guys i put the old collet on and cleaned the bearings real good now the clutch bell spins much smother, its funny the original collet is smaller than the ones that come with the new engine... have not started it yet but i hoping that it fixed the problem, now if i can get it tuned right. thanks again guys i will keep you all informed...
