ofna micro failsafe question
NJ
anyone with lst2 (jr rs300 receiver) used ofna micro failsafe unit? it doesnt seem to fit. does this not work with lst 2's stock receiver (jr rs300 receiver) ?? what failsafe unit will work with lst2? thanks everyone.
FL
RE: ofna micro failsafe question
i use the futaba failsafe,but you have to shave off a little so the connector can fit in the reciever.is that what you mean it wont work.
NC
yeah i use the venom also and it works great [link=http://www.killerhobbies.com/items/nitro-products/failsafes/venom-racing-fail-safe-adapter-vnr0620-vnr0620-detail.htm]here[/link] is one however it looks bigger than mine mine is [link=http://www.killerhobbies.com/items/nitro-products/failsafes/ofna-fail-safe-adapter-ofn91002-ofn91002-detail.htm]this[/link] size, i thing it is absolutely required as i have a large pond behind my house and have had to go swimming after my genesis before
FL
I use a Ofna micro failsafe with my Jr RS300 rx on both my LST and my T-Maxx. I simply shaved the plug down a little to make them fit. I've had them on my trucks for over a year now with no issues.
NC
yeah i forgot there is a little tab on one side of the plug that goes into the receiver that needs to go and make sure both plugs are plugged in the right way then turn on the tx and then the rx and apply full brakes and then set the fail safe with brakes applied
NJ
ORIGINAL: nitrorcjunkie
