aftershock fixed
aftershock fixed
well finally got the motor back for my aftershock with everything fixed...haven't tried running it yet...have plans on getting a temp gun before running
GA
RE: aftershock fixed
Their service is unbeatable, and some great mods are the HT pipe (right on, Terry12) lst2 spur gears, throttle/brake linkage.
Oh and a Dynamite engine brace is a must do
yea they took care of me pretty fast...i thought it was like a 5 day turn around....then i called losi to check on it...they said it had done been shipped back out...they only had it i think 2 or 3 days....anyways got it back and hopefully buy a temp gun soon and start over....
if you dont mind me asking what was wrong with your engine. im looking to get my father in law a aftershock.(dont have the money for another lst2)
MO
ORIGINAL: HpiDrifter420
mine just wouldnt take tune at all...it didnt over heat or anything like that...but it wouldnt idle...give it a lil gas it would die...and if u give it gas and let off it would idle high...and then a lot of time it wouldnt even start....so it turn out the head button wasnt threeaded right...it didnt let the glow plug go all the way down in like its suppose to...causing a leak...they sent it back and it runs ten times better now...i did test for airleaks to...and there is a small leak coming from the front bearing?? is that normal...its not a bad leak like if the bearing was out...its just a very small one
