lst 2 brake adjustment
LA
whats the best way to adjust the brakes? it seems like i have to loosen the little allen grub screw, and move it up a bit and tighten it, then is seems like theres to much brake, move it back, not enough. is there a mod thats out there that lets you turn a small knob like on my hellfire? and info would help,
thanks alot........................
MO
RE: lst 2 brake adjustment
you can adjust the amount of brake you apply with the radio, read them manual.... I don't have one in front of me or I would tell you.
ON, CANADA
Set your EPA (End Point Adjustment) on your Radio.....
Press the Scroll key till you see EPA, Then Press Channel key once you should see βTHβ (Throttle Adjustment) Push the Trigger for Brake
Adjustment, Then Press the Increase or Decrease keys to select the Desired Servo Travel......
