Super Reving problem
WI
hey everyone. its been a while, but i toook out the truck today and she ran good. got the lrp in it. anywayz, it ran fine, but once in a while it wouldnt put anything out and just rev high. i realized when it does that i can fix it by moving it back and forth on the ground. but it would do it every few mins. i have the FORWARD ONLY CONVERSION, so there is no revoerse servo to screw things up. im guessing it would be in the two speed or spur gear area. like i said, ran fine after i gave it a kick, spur gear is not shredded and everything appears to be fine. what do ya think??
PA
RE: Super Reving problem
PB Blaster works great for cleaning it and leaves enough oil residue behins to lube it for the next cleaining. I check mine and clean it every 2-3 tanks just to be safe.
