aftershock stays reved up
LA
I am new to the nitro rc world. I purchased an Aftershock second hand and it has a problem. I can get it running and start tuning it. Sometimes when I give it the trottle and then let off the engine will stay revved up. What would cause this? A carb. problem maybe?
RE: aftershock stays reved up
Then its running lean. This is where you need to start tuning. If it starts fine then you go do a wide open run and teh idle does not come down right away then you are running lean. Richen up the low speed needle till the idle drops.
