LRP 28 or Mach 454
IL
LRP 28 or Mach 454
Alright. I know some of you told me to just stick with the 454, but here is the thing. I part the LRP on ebay, so I have one sitting here. And I have the 454 sitting here. Cost is within $10. Which would you put in your XXL (or LST2? etc).
Another thought. I have the HT pipe, or my 086 pipe. 086, right?
My STS engine is either shot, or I will shoot it! I just don't want to deal with it anymore!
RE: LRP 28 or Mach 454
The 454 is an LRP spec2. The new LRP that everyone likes is the spec3. The spec3 has more power but both are good motors. I think you will be happy with the 454.
the LRP spec 3 is rated at 38,500 rpm, 3.81 hp 8+1 ports while the 454 is rated at 36,000 rpm's 3.5 hp and 7+1 ports. The spec 2 is rated at 36,000 rpm, 3.5hp and 7+1 ports. Exactly the same as teh 454.
ON, CANADA
They are the Same Piston/Sleeve/Crank....Different Carb and Cooling head/Backplate the Rest is 100% the same,
SH PT28XM1AC-P8 VS Losi 454 Engine Specs VS LRP Z .28R Spec 3
• BORE: 18.50mm VS • BORE: 18.50mm VS Bore: 0.73" (18.5mm)
• Stroke: 17.00mm VS • Stroke: 17.00mm VS Stroke: 0.63" (17.0mm)
• RPM: 36,000 VS • RPM: 36,000 VS Max RPM: 38,500
• Weight: 422 g VS • Weight: 390 g VS Weight: 15.9 oz (450g)
So the carb is where it gets its extra rpm's from. Also looking at the specs it says the number of ports are different? I use the LRP with the Sportwerks v2 carb. Same carb as the truggy version. SH does have some good carbs.
The specs listing they have for these engines is absolutely terrible....first thing is the HP rating is way out to lunch, second thing is they are not 8 port engines, nor are they 7 port engines....they are in fact only 6 port engines, they have 2 extra bypass ports but they are not intake ports...when we refer to port count we are talking about the intake ports and intake ports only...a LRP Spec 3 and a Losi 454 only have 6 intake ports.... I honestly wouldn't worry too much about the differences in specs as the specs listed are numbers rattled off by the marketing team
IL
Oh, andI have the same prob with my LRP carb... I threw the 28 in my XXL. But I still have high idle. Maybe you will have better luck.
Oh, and I was selling the carb for $24, but it was too low because I had three and they only lasted a day on eBay
