Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
Best Steering for LST
Old 03-13-2009, 11:50 AM
monsterbrad
Default Best Steering for LST
What are you guys running for steering up grades?
Arms
Servo's
Stuff like that to make the steering a bit more responsive!
Old 03-13-2009, 11:58 AM
Sugafree
Sugafree's Avatar
Default RE: Best Steering for LST
BAC Steering Link, can be got from [email protected]
With some Extra Servo Springs snapped over the Stockers, & JR 650's are a Good Cheap Servo Up grade......But theres Lots of Good servos out there if you got the Cash to Spend
Old 03-13-2009, 12:25 PM
monsterbrad
Anybody try the savers off the MGT?
Encountr
Encountr's Avatar
Sugafree,
i used your pict to pinpoint a question that i have (hope you dont mind that)
i have som slack in my steering and it seems to come from those 2 bolts i circled in your pict.
i looked at them and can say that they are held in plkace by C clips...
is it normal for them to be slack a bit?
looks like they a a bit loose in the servo arm but i see no way to tight them as they are held in place with C clips...
any thoughts?
Old 03-13-2009, 02:13 PM
Sugafree
Sugafree's Avatar
Theres a Little Play in them.....But if it Seems like alot.....I'd just Put New Savers on...or you could try adding a shim (There Cheap and as with most plastic Parts.......Should be replaced as they wear out)
and Yes you Can use the Savers from the MGT.......(And use Have to use them for Hitec or other Servos with a different Spline count .....with the Tops off the Stockers) But the Stockers with a Extra spring or 2 are just as Good if not Stronger.......
Old 03-17-2009, 08:40 AM
monsterbrad
Thanks guys I will just throw extra springs around my stockers
Old 03-17-2009, 09:14 AM
Airbus 9e
ORIGINAL: Encountr
Sugafree,
any thoughts?
'd think that you could swap in some RPM ball cups, and threaded titanium ball studs if you wanted to get rid of the slop....you can cut the cups down, and use a short turnbuckle to retain the adjustability.....I hate C clips....hehe
