engine for my After Shock/ mega baja
RE: engine for my After Shock/ mega baja
Get the LRP Spec 3 Z.28r pull start. This engine is ridiculously easy to tune and holds a tune for an entire summer almost.
Its got tons of power, easily throws around my close to 14lb basher lst2 and lasts quite a few gallons if taken care of properly. Its a Taiwanese engine so the front bearing goes pretty early around the 1 or 2 gallon mark but other than that it is the best bang for the buck engine.
My Feedback: (54)
the listing at tower hobbys says this ingine is a Associated engine and they are the same at TT and i have tryed a tt engine in the mega baja and it dident fit the engine mounts , i do like associated engines to. anything cheaper out there tho.
My Feedback: (54)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKYU8
this is what comes up when i do a search.
Correct but they are made by Sh for Associated. Thunder tiger makes their own engines but thats not the only engines associated uses.
