battery
NC
battery
Is [link=http://www.amainhobbies.com/product_info.php/products_id/20046]this[/link] a good battery or [link=http://www.amainhobbies.com/product_info.php/products_id/28005]this one[/link]
ON, CANADA
RE: battery
Sugafree, those are both AA size battery packs, which wont fit in the same space as a 2/3A receiver pack that most rc vehicles are made for.
full maxx you can build your own 1500mah RX pack with elite cells at cheapbatterypacks.com for about $17 (plus shipping) Elite cells are good. they aren't the best you can buy, but they are FAR from the worst.
ON, CANADA
RE: battery
Dude I'm Quite sure I KNOW What I Posted..... (maybe if you had a LST for more that a few weeks you'd be in the know of what peeps run)
And without going Lipo those are the best Packs for the LST's you can get..... Front Battery Mount Mod
Zip-Tie to the Front Shock tower,
Or you can Run it in the Rev Servo's spot with the FOC,(Like Mine)
Or if you have or run the LST1 Tank you can Fit it under the Tank after you Trim the Extra Plastic from the bottom of the Tank, (Like My other Truck)
Velcroed 2700 Mah Ballistic.
Originally Posted by Nu2the2
I went SJ & 2D's recommendation and Im very happy....I doubled up on the zip-ties to secure it's position up front....and it doesnt seem to affect air flight. It'sa Ballistic Battery.
NC
RE: battery
so if I build my own are the 2/3 A batteries the ones I need ... are they the same as the stockers ...and as far as soldering them does it hurt the battery to get them hot enough for the solder to melt and I guess they go + to - and the red wire goes from the + end and the black wire goes to the - end where there are no bars soldered , and I guess it is better to get the better bars to solder...oh yeah will the cheapo solder set from radio shack be good enough
RE: battery
I've soldered sub-C cells for years, and I would guess that you could get the 2/3 a's hot enough to melt the solder, but I'd still be careful.I have a Hakko 936 soldering station I use for most solder work.The light weight irons they sell at RS won't get the cell hot enough, and you might wreck them by holding the iron on them to get them hot enough. A good setup like a Hakko will do it quickly....I would suggest just getting a pre-made pack. Getting the cells arranged, then soldering them is enough fun with a jig when doing sub-Cs, so I would want to do it with 2/3a cells.....I use a Hyrdimax 1600 MaHr pack in my Aftershock, but my radio gear is pretty basic....Futaba PCM Rx with a 3004 for Throttle/Brake and the stock 590 JRs for steering. I usually don't spend hours running my truck though, so the 1600 will be plenty. Last summer all I ran was an HPI 1200, and when I took it out and tested it this fall, it was only holding about 700 MaHr....
RE: battery
ORIGINAL: Sugafree
RE: battery
ORIGINAL: full maxx
NC
RE: battery
ORIGINAL: dacaur
Yes 2/3A are what you have stock. When I said "build your own" I just meant go to the site and you select the cells and the pack configuration, but they solder it up, shrink wrap it, and attach the connector of your choice for you, included in the cost....
ORIGINAL: full maxx
RE: battery
ORIGINAL: TAKZILLA
....or go to post #4 and go with the hot set up Sugafree was showing you [sm=wink_smile.gif]
ON, CANADA
RE: battery
If his Packs are going bad from being up Front it's because He's not got them tight enough....and I Fail to see why you'd put a 2/3A Pack up Front in the 1st Place.......
The Whole Point of putting the Packs in the Front is for the 2600Mah+ AA Packs which won't Fit under the Truck and have a LOT Higher Capacity
Like I said before if your running a 2/3A Pack Get a Flat pack & put in in the Stock holder under the Truck and forget about it
NC
RE: battery
I had the stock pack under the truck and I got a hump pack up front then the stocker shorted out then the 1st hump shorted then I got the current hump and after charging 8hrs it has not glitched since so maybe it just was not charged good to start with but I have only ran 3 tanks since the charge but I want to get another in case this one is bad or goes bad cause I just got that feeling
ON, CANADA
RE: battery
It's a Hardcore Racing Titanium Battery Skid... http://www.hcrracing.com/index.asp?P...ROD&ProdID=353
