nitro storage
RE: nitro storage
i dont think it would hurt it, but when you store it, squeeze as much air out of the bottle as possible, then cap it. just be careful to not puncture the bottle.
RE: nitro storage
Cap the bottle so no humidity can get in and be absorbed by the alcohol in the fuel, and store in out of the light. Mine is on a shelf in the basement....
ON, CANADA
RE: nitro storage
Understanding Fuel
Model engine "glow" fuel is made up of three key elements: methanol, oil and nitromethane. Many fuel manufacturers include other additives that are designed to solve any number of common problems that may occur with our fuel. But for now, let's only address the most common elements of the fuel and how you can care for your fuel to keep it fresh and stop it from going "bad." These steps will ultimately make your model engine operations easier.
Why would fuel go "bad"?
The largest portion of the fuel is methanol (alcohol). Methanol is hygroscopic; it attracts moisture. This can cause your fuel to be contaminated with water, which will cause poor engine performance. Additionally, the UV rays in sunlight will eventually break down the nitromethane if the fuel jug is stored in sunlight for long periods of time.
How can you tell when your fuel has gone "bad"?
The first indications will generally be the inability to start the engines at previously run needle-valve settings. Another clue might be that the engine has very poor idle, runs but bogs down tremendously during run up and/or will not attain the same RPMs you are used to.
How do I keep my fuel fresh?
If you have the opportunity, look for someone at a flying field on a sunny day who has a jug of fuel that is only ¼ full. What you may notice is that there are droplets attached to the top and sides of the fuel. This is the moisture in the air that is condensing inside the jug because of the greenhouse effect of the semi-translucent plastic jug. One way to overcome the greenhouse effect is to store your fuel in a metal can.
You can also combat the effects of the moisture in the air by squeezing all the extra air from your fuel container at the end of the day or transferring your fuel into smaller containers as the level of the fuel is reduced in your gallon jug. Many pilots will invest in half-gallon or quart-size containers and only bring that amount of fuel to the field on any given day. This allows their main supply of fuel to stay at home in a controlled storage environment, virtually insuring problem-free fuel.
http://www.horizonhobby.com/Articles...ArticleID=1250
GA
RE: nitro storage
ORIGINAL: jikkuria
i forgot what concrete does to it, but i read it some where, can someone remind me?
None of the fuel manufacturers say anything about it, at least not that I can find. Personally I think it's a myth to go along with not storing batteries on a concrete floor. It may have had some truth to it at one time but with modern materials does not apply anymore.
NC
RE: nitro storage
ok well I already squeeze the air out but the wife will have to understand that this $35.00 jug of fuel will have to stay in the house and now I run O'donells ...it is a white jug not clear or opaque ...and I did know about the sunlight...thanks for the info you all
RE: nitro storage
ORIGINAL: DaveG55
I've heard that before too but never heard a plausable explanation on why not to store on concrete.
ORIGINAL: jikkuria
GA
RE: nitro storage
With batteries it was the old (real old) case material and it became a kind of "legend" not to store them on concrete. Heck, I know it's ok to do but still put them on a board, not directly on concrete. The only thing I could find said that it only affects large lead/acid batteries because the cold concrete can cause stratification of the electrolytes. The same stratification could go for nitro fuel I guess. I would not think that moisture absorbtion would be the issue though since I find it highly unlikely that exterior moisture could make it through any modern containers. But again, I store the stuff on a shelf. Kind of like the old Chinese people. When asked why they embraced Christianity but still kept their old Gods they replied, Of course I believe in the One God but why take the chance and anger the old ones? You know, I'm just covering all bases, since it costs nothing to store batterys or fuel off of concrete why not do it?
